ruckdr
ALL,
Installing the Modifry Redline Shift Beeper, will end your RPM shifting concerns forever!!
NEVER TAKE YOUR EYES OFF THE ROAD OR TRACK TO VIEW THE TACH OR SHIFT LIGHT.
The Redline Shift Beeper connects to the Viper Tach Wire (see instructions), and will provide a series of 3 short "Pacing Beeps" prior to your set maximum RPM setting, which will then provide a continuous beep tone. Your Maximum RPM setting is via 2 dials, one in increments of 1000 RPM, the other in increments of 100 RPM.
The 3 short "Pacing Beeps" can be set to 100, 200, 300 RPM prior to the Maximum setting, your choice. So, for example if you set your maximum setting to 5500 RPM, and the "Pacing Beeps" to 200 RPM, you will hear a beep at 4900, 5100, 5300, and a continuous tone at 5500 RPM.
The Modifry Redline Shift beeper can be set for 4 cyl, 6 cyl, 8 cyl, and Viper (5 cyl) applications.
I have had mine installed for 2 track days now, and can only say that this is the only way to appreciate when to shift your Viper; JUST LISTEN FOR THE BEEPS.
Is it a little creepy never looking at the tach?, yes; is it a little creepy never taking your eyes off the road?, NO.
http://www.modifry.com/products/rlb/index.htm
http://www.modifry.com/products/rlb/RLB-2 Manual 1.8.pdf
Don Ruckman [email protected]
