It is correct that I’m not familiar with the ROE kit on the viper.
However I've been building and tuning cars for many years
Makes sense why he has no air temp readings. Obviously Roe does not relocate the Air temp sensor, or do they ?
Here is the factory Viper ACT corrections. [ from my 97 GTS ] different year models will vary, most likely not by much.
MAP_torr
296 395 494 593 691 787
deg_c
-40 0 0 0 0 0 0 0
-20 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
20 0 0 0 0 0 0 0
40 0 0 0 -2 -2 -1.5 -1
60 0 0 -1.5 -2.5 -2.5 -2.5 -2
70 0 0 -2 -3 -3 -3 -2.5
80 0 0 -2.5 -3.5 -3.5 -3.5 -2.5
90 0 0 -3 -4 -3 -3.5 -2
The first column is the Air temp reading in C
and left to right is Map readings.
So moving your AIT to the manifold will allow you some timing retard part throttle & beyond when you most need it.
[the bigger picture is go have some sort of tuning software , obviously., I’m just adding to the conversation ]
I have a friend with a Roe charger kit on his Viper truck.
I will be tuning it, but not sure when ---
cause it has a rod hanging out the side of the block.
OUCH!
Yes it was detonating !
WE ordered the racer package for it, but temptation got to him and he just couldn’t lay off the throttle.................
Adjusting for injector changes is very simple with the software.
You would not need the VEC,
I also must add, that I have no experience with the VEC.
Never was in the position to use one, so I don’t have a clue as to what it does.
Vince
